Jeff's 'Stupid Roadster Trick' #1
Hey Roadster Owners, know what this is? Where this is?
<img src="http://woodyjdb.home.comcast.net/images/switchbutton1.jpg">
Yes, it's a switch. Left top latch, drivers side. It tells the TT logic controller somewhere that you top is down, or latched, or unlatched, etc.
It also prevents your heater/AC fan from spinning at maximum.
Try it while stopped, engine runing, A/C on max, then push the switch to the right. Notice what happens?
I tried this last year, but only recently made this piece.
It has been alternately raining here, followed by hot, humid weather.
Top has been up and down. Hot and humid again today
By fabing this out of a small piece of wood, and attaching some small velcro pieces to it...
<img src="http://woodyjdb.home.comcast.net/images/switchbutton2.jpg">
It goes here.
<img src="http://woodyjdb.home.comcast.net/images/switchbutton3.jpg">
Now you can run the A/C at max. while cruising with your top down!
Oh, but don't forget to remove it before you try to put the top up.
Actually, the logic thinks the top is up and latched, and won't operate the top, unless you do it manually.
It goes here.
