John S..it says DTC catalyst (BANK 2) below threshold
I'm thinking the A/F mixture has become super free flowing and not creating a proper fuel mixture to the amount of air. Maybe I'm talking out of my butt hole but I need your help. What should I capture for you and I'll Email you my results. Let me know what blocks you want to determine an idea of what I need to purchase. I don't want to waste $ on unnecessary parts. You saw my engine its the same as yours AMU series 5V K04 Turbo- w/ MTM 2.75 "downpipes high flow 100cpsi catalyst and 2.75" cat-back exhaust. BMC CDA w/ aluminum intake 3.50 + g/s@idle 800-810 engine speed and ported TB, MTM ECM chipped (Gen. 1b version right before Gen II) 1020mbar command pressure Boost 1020/30 @intercoolers depends on atmospheric temp has dropped as low as 1000mbar command pressure , TURBOXS DV w/6 washers, removed windshield insulation for better engine bay heat exhaustion, H&R coilovers, neuspeed front and rear swaybars, HRE wheels and Pilot Sports staggered 225/40,255/35.
that's all folks...for now.
2001 TT Roadster
2001 TT Roadster
Check the secondary O2 sensor wiring. It's possible it was damaged during the cat. Installation and
it failed over time. You might also want to check the primary O2 sensor connector for heat damage and to make sure the pins haven't backed out of the connector housing. Mine just about melted off.
AvantMnkyA4
03-22-2005 02:56 PM
AIRSTTRIKE
Performance and Tuning
12-22-2001 08:58 AM
kosta_s3
Audi A3 / S3 / RS 3
01-11-2001 12:47 AM
