With just lowering springs only, Is it going to be
Eighth Member of AudiWorld. God-like, glorious and all-knowing.
Depends on how low you go...
With a reasonable drop, you will almost certainly need the kit with a TTR, probably need one with a TTC.
I highly recommend you do shocks at same time!!!
On my 180 Quattro Coupe I put H&R Sport Spring on with my stock shocks. The car looked good, but did not ride good. I highly recommend you change shocks at the same time. The labor cost should be the same, and you'll need an alignment anyway.
You will want a camber kit if you change springs (even if you do shocks also) unless you get some that do not change ride height. Without the camber kit, you will have a lot of negative camber and will wear out your tires faster.
If you don't care about tires, then no need for the camber kit.
-Ryan E.
-Ryan E.
