lol... I can't get the old FPR out
I had to pry on mine a little a couple weeks ago, to get my 3 bar back in. I put a screw driver on
the top lip above the clip, and under the vacuum tip on the FPR, and GENTLY pushed up. It came up pretty easily that way.
DO cover the area with a paper towel or something in case some gas squirts out.
It was also VERY full of gas, and the new FPR won't go in to a "wet well". It took a ton of paper
towels to suck out the gas. It seemed like I would pull some out, and more would go in (it was more full AFTER sucking some out!). I finally folded the towel, and sucked out fluid from the edge only, and about 5-6 towels later, the whole thing was dry.
It didn't do that the last time I did it, but it did squirt at me last time, so maybe it purged itself...
Dani, I used a flat blade screwdriver and gently pried it loose. As Mike said...>>
fuel is under pressure. Have a rag around the fpr.
Be careful...:-)
I used my palm to press the new one back.
Be careful...:-)
lol... once the seal broke that thing popped out of there
I was prying gently and pulling with the other hand and suddenly POP!
it's swapped now though. Thanks
