Look what Brown did for me today....
<center><img src="http://pictureposter.audiworld.com/47675/img_6424.jpg"></center><p>
brown delivered them anyway...
Bilstein HDs, Eibach Springs, full kmac (if needed). They'll be going on next week, hopefully. :-)
oh,...and a couple of FRS radios. Just need to get a gadgeTT V1 now.
All it says is....
"Kit replaces REAR control arms upper & lower "INNER" bushes allowing (ongoing) adjustment for more even tire wear/traction"
and...
TAKE ALIGNMENT READINGS 1st
refer to workshop manual and observe all safety procedures.
Use the extraction tool supplied to remove bushes and install the new bushes using the grease to lubricate the 'inner' surfaces.
WHEEL ALIGNMENT
simply rotate bolt heads - unique k-mac system
(allowing accurate adjustment direct on alignment turntable)
Make sure lock nuts are loose. Once required setting is obtained, hold in this position and fully torque lock nuts to 72 NM/53ft/lbs.
This is what it says on the box as close as I can duplicate....yes it really does say "bushes".
There is no other separate instruction sheet, but it does have some standard diagrams illustrating what camber, caster, & toe adjustment are in general. ....hope this helps. whew!
and...
WHEEL ALIGNMENT
SereniTTy
01-08-2006 05:30 PM
Wjballz
03-06-2005 02:15 PM
Quattroleap
08-30-2004 12:35 PM
Headed down to Johnson's Alignment to get alignment done today. Left with negative camber all around
JCJiffy
05-13-2003 11:21 AM
