Look at what's in the Garage waiting to be installed
<center><img src="http://pictureposter.audiworld.com/80527/carparts.jpg"></center><p>I finally got the last of my suspension:
Parts to be installed:
KW Variant 3s,
GroundControl Front Camber/Caster,
Rear Camber TieBars,
SS Brake Lines,
Hawk Blues,
Brembo Slotted,
15mm spacers,
19mm Neuspeed Rear Sway bar with the new ribs,
Forge Race DV with Adjustable Vacuum Connection...
I installed the Forge Race DV and already blew a Diaphragm. I had to really adjust my boost machine compared to the stock valve.
KW Variant 3s,
SS Brake Lines,
Hawk Blues,
Brembo Slotted,
15mm spacers,
Re: you're gonna love the kw's.
What are your recommendations on the rear? I've seen a lot of post dealing with customizing the rear of the V3s?
i shaved the bases off the rear perches
that got the ride height about where i wanted it without compromising the integrity of the rear components. i've put about 12K miles (14 months) on the setup now without any problems.
huh?!
have you looked at the kw springs? they have flat tops and bottoms and fold in on themselves during compression -- further, you can't cleanly just cut them back by 3/8".
the bottom of the perch has no structural significance. i also ran this solution by kw and they saw no issue with it.
here is the perch when finished ... can't imagine a cleaner fix than this.
<img src="http://m3.mayzurk.com/meem/tt/parts/kw-perches2.jpg">
