New to Audi TTs
Old 04-22-2012, 02:40 PM
lawnerd's Avatar
Default New to Audi TTs
Hi. I just got a 2005 Audi TT quattro roadster. It has 73,000 miles and the timing belt has not yet been replaced.
My question. Is this a job that I should rely on an Audi Dealership to do or should I take it to an Indy.
It seems that this same or similar engine is in several Audis and VWs. Makes me think this is common enough that an Indy should be able to pull it off, but would like your input.
Old 04-22-2012, 05:05 PM
ericgl's Avatar
A well respected indy will be fine.
Old 04-24-2012, 08:04 AM
AudiMick's Avatar
Make sure they do the entire job, if they know what they are doing they will change water pump, belt, tensioner and thermostat.
Many shops skip the thermostat, however you will almost certainly end up replacing it very soon .
Old 05-05-2012, 02:40 PM
lawnerd's Avatar
I did the job myself. I followed the excellent write up on the net by Blue top tt.
It is involved and took about 10 hours. I used the kit from dieselgeeks, which I highly recommend. They include three screws for removing the water pump that saved the day.
The old timing belt was in decent shape but the belt tensioner was worn.
kkeriazes
14
06-21-2010 06:17 PM
CopperCounTTry
2.0T FSI Discussion
08-21-2008 05:30 AM
slugo10
11
08-15-2005 08:20 AM
Quick Reply: New to Audi TTs
