Loss of power and code 17536...what does it all mean???
Old Jul 30, 2001 | 08:20 AM
RichP's Avatar
Junior Member
Default Loss of power and code 17536...what does it all mean???
17536 Long Term Fuel Trim Mult System too lean Bank 1
Once I got the code it was 35-10 intermittent
2nd time it was 35-00
Anything obvious I need to check like my Bailey...could it be a boost leak(wouldn't that return a RICH code)
Car feels stock right now and its killing me!!
Old Jul 30, 2001 | 08:56 AM
EighTT's Avatar
Eighth Member of AudiWorld. God-like, glorious and all-knowing.
25 Year Member
Default Actually, that code means...
A UFO hovered over your TT. Aliens from another galaxy disabled your car while rendering you unconscious. Then, you were transported to the mother ship, where you were "probed".
Finally, your memory of the incident was erased and you were returned to your TT where power was restored. That fault code is the only evidence (other than a sore bum) that the incident actually occurred!
john s's Avatar
Member
Default I think that means it's running rich.
Can't trim any leaner. I usually get things back asswards though.
Old Jul 30, 2001 | 09:24 AM
RichP's Avatar
Junior Member
Well I did experience a "loss of time" as well
Old Jul 30, 2001 | 09:57 AM
LusTT's Avatar
Default Came across the same problem on the Vag-Com site...
Their explanation is a bad MAF sensor causing the "system too lean" DTC. The explanation went on to say you should fire up your engine, go into engine electonics, measuring block 08, read channel 032. Fields #1 and #2 should read 0.0%. Specs say that you can go +/-5% from 0.0%. If the MAF sensor is bad, the reading, apparently, will be way outside the target value. Responder was guessing 25%.
Let us know if this fits your situation and what your actual reding is.
Old Jul 30, 2001 | 10:16 AM
RichP's Avatar
Junior Member
Default Thanx for the info, I will check this out tonite when I get home and report back what I find.
If the MAF is bad, should I upgrade to a 225 version with one of those LLTEK cold air intakes!?!?!
Old Jul 30, 2001 | 04:50 PM
RichP's Avatar
Junior Member
Although I didn't hook up the VAG, I did disconnect the MAF and now the car runs great...wierd.
Old Aug 1, 2001 | 03:19 PM
RichP's Avatar
Junior Member
Vag-Com results: Chan#32 Field 1: -0.9% Field 2: 23.4%
 Pouria Savadkouei
 Michael S. Palmer
TT01Q
Mar 11, 2012 06:36 AM
TT01Q
May 21, 2011 06:30 AM
PaulW
10
Nov 19, 2008 06:42 AM
euromotorsports
12v V6 Discussion
Feb 5, 2005 03:35 PM
Ghant TMK
Dec 27, 2002 01:42 PM
