Malfunction Indicator Light
Three years and counting and zero problems with the '01 TTRQ. Now the CHECK engine warning light is coming on intermittently -- one day its on all the time then not for a few days. Can't get an appointment with at the stealer for 10 days. Any thoughts about what it could be? Have checked the obvious fluid levels.
find someone nearby with a VAG-COM, should tell you more about what's wrong.
post where you are and maybe someone will chime in.
could be anything...but most likely, a MAF issue...could be that the MAF is just dirty. I've cleaned mine twice already because of CELs.
Vacuum hose somewhere?
check the ones around the N75 especially. But def find a VAG. If you are out of warranty, the price of the VAG is recouped with saving your first visit to the stealership, usually.
unc99206
12-16-2005 06:27 AM
Greyhaven7
11-27-2005 05:24 PM
