More brake questions, since we are on that subject......
When you compress the brake piston, I have read that you may need to remove some of the brake fluid or at minimum remove the brake fluid cap, is this typical? If you compress the piston slowly is any of that necessary?
Thanks
Thanks
I didn't when I changed my front pads and ended up with a bit of a mess.
You probably want to take the cap off and keep an eye on it to make sure it doesn't overflow while you're compressing the pistons. You may need to remove some of the fluid.
slightly disgruntled
05-01-2006 05:40 PM
darkman
05-26-2003 05:52 AM
