My (long) list of warrantee repairs to my TT ...
While organizing my apartment this weekend, I went through my service records for the TT. The following is my list of "problems" that I have had with my TT. Note that all but one of these (the starter motor) were really minor (other than aggravation). Still, it makes me wonder whether I really want to absorb the out-of-warrantee repair cost for this car. Comments welcome.
At 5K service:
1) Driver's side seat heater won't return to set temp and must be cycled - not repaired, part on special order.
2) Beeping in between tracks on CD player - could not duplicate problem (I gave up on this one as not worth the trouble).
At 10K service:
1) (again) Driver's side seat heater won't return to set temp and must be cycled (see above) - this time they claimed they could not duplicate problem (I gave up on this one too, because by now the passenger side was doing the same thing and I figured as long as they work the same way...)
3) Intermittently, car will not turn over - fixed by replacing starter motor.
In between 10&15K service:
4) Washer fluid leak from front of car - fixed by replacing driver's side "alien."
At 15K service:
5) Knocking noise underneath car at slow speeds - fixed by "tightening everything up"
6) Replaced failing DV with H-series model
At 20K service:
7) Driver's side windshield washer jet clogged - fixed
8) Driver's side view mirror loose - fixed by replacing mirror glass
At 25K service: no problems!
At 30K service:
9) Driver's side windshield washer jet clogged (again) - fixed
10) Coolant warning comes on at cold start - topped off coolant, checked for leaks (none found); fixed problem (fix lasted about 2 months, see below)
At 35K service:
11) Passenger side windshield washer jet clogged - fixed
10) (again) Coolant warning comes on at cold start - topped off coolant, checked for leaks (none found); fixed problem (fix lasted this time only 1 month, so it looks like I'll be revisiting this at 40K).
At 5K service:
At 10K service:
At 15K service:
At 20K service:
At 30K service:
At 35K service:
TTonyB
01-29-2002 06:03 PM
PaTT
04-06-2000 12:01 PM
