Nails on rear tire... anything I should know before I take it to the shop ?
A while ago someone warned that caution should be taken while taking out the tire... I am kind of nervous about this. Help !!!
Yes, do not let the tire shop use a plug.......
........Have them dismount the tire and use a patch on the inside. This is the only proper way to repair a hole in a radial tire.<p>Jason Dale
Lamborghini technician
Exotic Imports
SLC, Utah
<img src="http://pictureposter.audiworld.com/AudiWorldPics/2000/burnout2sig1.jpg">
2000 'Rumble in the Rockies' Sportsman class winner
Exotic Imports
SLC, Utah
Re: Nails on rear tire... anything I should know before I take it to the shop ?
My caution is to examine your wheel carefully before you have anything done with the tire. If they do install a patch, it will mean removing and remounting the tire... which could cause damage to the edges (rim) of the wheel... Be sure you get assurance that the place you bring it to be repaired has the proper equipment to mount the tire, and balance it... without causing damage<p>2001 225 Quattro Coupe Silver / Ebony
chairman
Wheels & Tires Discussion
02-20-2005 10:18 PM
S4-GTR
12
09-23-2004 08:25 AM
