Need help to decipher engine fault codes
Old Jul 27, 2004 | 06:31 AM
Audifan8's Avatar
New Member
Default Need help to decipher engine fault codes
Can anyone please help me to decipher the following engine fault codes from a diagnosis report? What has caused the TT's engine to break down? Are there any codes in the attached list that may suggest that the engine is over revved? Thanks very much.
02 -Interrogate fault memory:
11 Fault detected
17963 P1555 035
value above maximum charge pressure
16487 P0103 035
Mass or Volume Air Flow Circuit.
High Input
16712 P0328 035
Knock Sensor 1-G61 Circuit
High
16496 P0112 035
Intake Air Temperature Sensor 1 Circuit
Low
17953 P1545 035
Throttle valve control system
malfunction
17953 P1545 035
malfunction
17987 P1579 035
Throttle Valve Control Module - J338-
Adaption not initiated
17925 P1517 035
Main relay =>-J271
electrical fault in circuit
18010 P1602 035
Voltage supply - terminal 30
Voltage too low
17645 P1237 035
Cylinder 1 injector - N30
open circuit
17695 P1287 035
Turbocharger divert air valve - N249
open circuit
Old Jul 27, 2004 | 06:45 AM
AxeYrCat's Avatar
Member
I posted a reply the first time you posted this. Did you not see it?
Old Jul 27, 2004 | 06:54 AM
|everso!|'s Avatar
Default hijack. yeah, i really love your TT Chris..it's fantastic
internal double hijack: are you coming tomorrow to chicago?? or wednesday...we were discussing your guitar situation if you wanna play tomorrow night on TOF.
let us know what the plan is.
Old Jul 27, 2004 | 07:00 AM
AxeYrCat's Avatar
Member
I'm going to make some calls... I still don't know. =/
mountainsurfer77
Aug 8, 2007 04:37 PM
bodhi
Apr 4, 2006 09:21 PM
dirrTTy
VAG-COM Discussion
Sep 15, 2004 11:29 AM
Audifan8
Jul 24, 2004 03:45 PM
A-pfour
Dec 14, 2000 02:50 PM
