Need some assitance with control module coding
Car is an 02 225 TT coupe, ECU code AN.
If anyone has the chart to figure out the control module code that would be a big help. I am not sure of his username on here but he is a member and may chime in when he sees this.
Also did Audi switch to immo3 in 02 also like VW? Just wondering which way I need to go about getting it aligned to the cluster, easy method or hard.
Thanks in advance for any help.
The immo you need the vin and the code if its immo 2. Dealers switch to geko or whatever it is where they have to log in right from the dealer and do it. However most can still manually access it, they just havent' tried so think they can't.. So you go in with the numbers and 20 bucks and convice them to try it
Secondly there is no reason to pay a dealer 100 bucks an hour minimum charge they would try and do for coding the ECU when I can do it in 2 minutes myself.
On top of that they would then charge for the immo coding probably..
Is this possibly an immo 2 and the K is immo 3??
I'll go toss it in now and see what happens.. module coding doesn't have to be set to see if the immo is there or not.
