O2 Sensor Codes
Old Jan 10, 2005 | 01:10 PM
OldSchool AG's Avatar
Senior Member
Default O2 Sensor Codes
I assume it's possible the connector is dirty or the wire got pinched. Can anyone with a Bentley confrim that "B1 S2" refers to the post-cat sensor? I'm sure the last one, 17545, is due to my dying MAF.
TIA!
17522 - Oxygen (Lambda) Sensor: B1 S2: Internal Resistance too High
P1114 - 35-00 - -
17526 - Oxygen (Lambda) Sensor Heating: B1 S2: Open Circuit
P1118 - 35-00 - -
16524 - Oxygen (Lambda) Sensor B1 S2: No Activity
P0140 - 35-00 - -
17545 - Fuel Trim: Bank 1 (Add): System too Rich
P1137 - 35-10 - - - Intermittent
Old Jan 10, 2005 | 01:23 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Re: O2 Sensor Codes
Yup...it is the rear one. Do a block 32...You can do that sitting still...Negatives are too rich: From the Bentley.......
Oxygen sensor adaptation value in range:
-10.0 to .-25.0 %
Leak in intake area (pressure side between turbocharger and intake manifold)
- Check intake system for leaks and repair false air Page 24-75 .
Oil thinning
- Change oil or perform swift country open) road test
High oil consumption
Mass Air Flow (MAF) sensor faulty
- Check Mass Air Flow (MAF) sensor Page 24-67
Evaporative Emission (EVAP) canister purge regulator valve remains stuck in open position
- Check Evaporative Emission (EVAP) canister purge regulator valve Page 24-136
Fuel pressure too high
- Check fuel pressure regulator Page 24-39
Fuel injector does not close
- Check fuel injectors Page 24-44
Oxygen sensor heating faulty
Oxygen sensor faulty
- Check oxygen sensor heating Page 24-108
Old Jan 10, 2005 | 01:27 PM
Senior Member
Thanks!!!
Old Jan 10, 2005 | 01:28 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Here's a test sequence..
Test sequence
- Disconnect 4-pin harness connector to oxygen sensor behind catalytic converter; Component location overview Page 24-6 .
- Connect multimeter between terminal 1 and 2 of relevant connector for resistance measurement.
Specified value at room temperature: 1 to 5 ohms
Note:
At higher temperatures, resistance climbs sharply.
Replace sensor if not within range..
Old Jan 10, 2005 | 01:31 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Here's a voltage test...
These are only $23 anyway.....:-)
Testing primary voltage
- Disconnect the 4-pin harness connector to the oxygen sensor behind catalytic converter (below a black plastic cover at underside of vehicle)
- Connect multimeter between terminal 3 and 4 (4 is at the curved end of the plug) for voltage measurement.
- Switch ignition on.
Specification: 0.400 to 0.500 V
- Switch ignition off.
If specified value is not obtained:
- Test oxygen sensor wires Page 24-107 .
If specified value is obtained:
- Replace oxygen sensor behind catalytic converter.
Senior Member
Sweet! To the garage, Batman!
Old Jan 10, 2005 | 01:54 PM
Senior Member
Default She's dead>>
no reading whatsoever on multimeter (thus the open circuit DTC). Guess it's time to put together a parts order.
timeport11
Q7 MK 1 Discussion
Aug 27, 2017 08:24 PM
eCoastAudi
Aug 12, 2017 03:36 PM
steve77
VAG-COM Discussion
Jul 11, 2007 10:35 AM
BluDemon
Nov 10, 2004 03:13 PM
97A4 1.8T
Sep 23, 2000 07:07 AM
