OK... want to check a spark plug or two for color etc>>
<center><img src="http://users.sisna.com/Rave_nGTI/coils.jpg"></center><p>
what size socket do I need and how in gods name do you get the coil packs off? I'm used to plug wires..... do they just pop off like a wire would?
also... from pass side to drivers side... is it 1 2 3 4 or 4 3 2 1 and which two would be the best to check (like on mustang V8s.. its usually 1 and 8)
TIA
TIA
Some BAD color on this website >>
<ul><li><a href="http://www.motocross.com/motoprof/moto/mcycle/plug2/plug2.htm">http://www.motocross.com/motoprof/moto/mcycle/plug2/plug2.htm</a</li></ul>
ok ok... Engine Cover off, look at the Pix from Jeff Bipes website >>>
<center><img src="http://pictureposter.audiworld.com/30405/icintakehose1.jpg"></center><p>You'll See the coil pack right where the Turbo Pipe turn is in this pix...
2 Allen head screws per pack 7 MM (maybe) - it's the one I always lose down the engine...
The Transmission end (# 3 & 4)(?) have a BUNCH of Vacuum hoses that you just have to disconnect and remember HOW they go back on !
The actual coil pack just pulls straight up and are 7 or 8 " long. Plug socket needs narrow sidewall - I'm traveling so can't verify the MM size, but will need extention(s) for sure
