Overheating Problem
Old Sep 9, 2018 | 02:18 PM
Rangerjoey's Avatar
Default Overheating Problem
Just got a 2001 TT quattro that was given to my son. Second time i drove it it overheated. Replaced the rad cap water pump timing belt and thermostat. Still overheating. I can drive it about 5 miles then when i idle it starts to overheat. Both fans do come on. Did a pressure test and it will not hold pressure. Shows a small leak in the rad. Even though it has plenty of coolant will the small leak cause it to overheat? Also ruled out head gasket with a block test. The return line gets hot then cools off so the flow is stopping.
zmatania
Sep 19, 2018 07:08 PM
quattro0
Apr 14, 2017 04:46 AM
5000S Kid
Jun 15, 2005 03:45 PM
LEHIII
Apr 23, 2003 01:17 AM
