Paging Swing (Camber & Spacer help)
This is the view of my car and whilst I welcome the comments I've had when people have been following me (car sits and turns good) is this too much camber?
<img src="http://images.fotki.com/v1/photos/1/11117/44170/101-0179_IMG-vi.jpg">
<a href="http://images.fotki.com/v1/photos/1/11117/44170/101-0179_IMG-or.jpg">HiRes Version</a>
The high res version gives a good picture of the almost 20 degree angle I have in the rear. What's the best way to get this adjusted
Alignment, spacers and K-Mac? (I can split a kit with a fellow forum member)
TIA
TIA
try to get a shot more from the rear. Eyeballin wont tell you much anyways...
figure what spacers you want, get them put on, get the kmac installed, and then take it to the alignment shop to have it put back into spec. All u need to have done
Put your hands on the K-mac kit, install, then allign. That should do it! You might want to >>
go visit Steve's (TTschwing) Fotki site for camber kit install pics. I'm not sure if half a kit will get you there or not. I suspect it will. You'll still want to have a slight amount of negative camber in the rear for handling.
After all, tire wear is a little overated anyway.
Avantugofast
03-20-2008 03:51 AM
RallyVermont
10-06-2006 05:17 AM
TToro 3.2
08-08-2005 03:54 AM
AudiNutA8A6
05-19-2004 06:22 AM
