Please Help!!
Old Aug 25, 2003 | 02:51 PM
Jetsandhu's Avatar
New Member
Default Please Help!!
After jus fitting an aftermarket Head Unit into my TT Coupe, the FM stereo just doesnt work!! Ive asked this question earlier and someone suggested Jeffs Site (cheers TTSchwing), but the site dont tell me anything bout the aerial or signal booster if installed. Has anyone else had a problem with the FM Stereo after fitting a different head unit?? I do not have the BOSE system...... There must be some wire that I have left out!!! Can anyone please help... I need my Radio!!
Thanks
Old Aug 25, 2003 | 02:58 PM
Quattrings's Avatar
The antenna is factory amplified. Make sure to connect the power antenna lead to the radio...
Old Aug 25, 2003 | 04:20 PM
JustJeff's Avatar
Default Not true. The connector from the lead going to the H/U is non-aftermarket std....
you need to;
1. match the conenctors with an adapter.
(impossible to find)
2. Cut the connector off the OEM wiring harness.
Splice it to an aftermarket type Motorola plug.
OR
3. If the after-market H/U haa connector on a short length of cable, you can actually cut *both* ends off, strip the insulation on both down to the shielded center conductor.
Splice them together. (solder pref.)
Tape with electrical tape.
Splice the shields together.(just a few plaaces will do.)
tape it up.
It will work.
Old Aug 25, 2003 | 05:11 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default And...The factory amplifier is passive..>>
No separate power lead....
Old Aug 25, 2003 | 05:15 PM
Quattrings's Avatar
Default Guess its different than the A4 with the antenna in the rear window then...
No wonder the reception has always been so poor Makes sense.
Old Aug 25, 2003 | 05:41 PM
JustJeff's Avatar
Default Not true either. The *antenna* is in the coupes rear window...
It's the connection that he has a problem with, I believe.
Old Aug 25, 2003 | 05:45 PM
Quattrings's Avatar
Default I know, Im saying that the A4 has an amplified antenna...
Which is different than the TT, which does not
Past Audi's and VWs have used a special adapter that has a power lead inside the antenna adapter. Metra carries this product as well as probably a few others (such as Scosche)
See Crutchfield link:<ul><li><a href="http://akamaipix.crutchfield.com/products/2002/097/x097din12-f.jpeg">http://akamaipix.crutchfield.com/products/2002/097/x097din12-f.jpeg</a</li></ul>
Old Aug 25, 2003 | 06:00 PM
JustJeff's Avatar
mis-understood yer meaning
 Michael S. Palmer
Old Aug 25, 2003 | 06:05 PM
Quattrings's Avatar
No worries... Is anyone positive that something like this isn't required on the TT?
Old Aug 26, 2003 | 01:06 AM
Jetsandhu's Avatar
New Member
Default Re: Not true. The connector from the lead going to the H/U is non-aftermarket std....
Thanks Jeff,
But which lead of the many on the OEM connector do i need to power up??
SolidFish
May 19, 2009 01:58 PM
Sal R.
Nov 21, 2007 10:42 AM
computrtutr
Nov 30, 2005 06:28 AM
barbos011
Apr 26, 2005 10:05 AM
