please read... having some problems with boost
Car wasn't seeing potential.. only seeing peak boost at 16-ish psi. (autometer boost guage) I took the vac line from the DV and plugged it off. Then I took the vac line for the FPR and ran another T (same vac line the boost guage is tapped from) and tapped another vac line to run to the DV (thinking this would solve my boost problems). Car seems to run a little better, but I am only seeing 7-8 psi peaks and tapering to 4-5psi. Scanned with ProDiag and got no codes. Checked APR chip and it's it 93 octane mode. No visible problems with the vac lines.
HELP!! =)
hmmmmmmmmmmmmm................ *thinking*
Hope this helps.
