Problem
1) The engine speed is controlled by the throttle alone when the clutch is disengaged ("in"). It is equal to the layshaft speed when the clutch is engaged.
A) The clutch disconnects the engine from the layshaft when you step on the pedal.
2) The layshaft speed is equal to the engine speed when the clutch is engaged. The layshaft speed is related to the road speed when a gear is
selected. Therefore, when the clutch is engaged AND a gear is selected, the engine speed is related rigidly to the road speed. (Nobody spins the wheels in this schematic outline!) When the clutch is disengaged AND the selector is in Neutral, the layshaft coasts down freely, regardless of either engine or road speed.
B) The gear selector disconnects the layshaft from the transmission gears when you select "Neutral", and connects the layshaft to a specific transmission gear when you select one.
3) The various transmission gears are being pushed around by the road speeding under your car via the differential and driveshafts. All of them
are spinning at different speeds in rigidly defined relationship to each other. If your tires are not slipping, the speed of the system is rigidly proportional to your road speed.
I think that is a pretty good description. What why would it break or cause problems?
