Power/Battery Issue continued...
Well I got a new Battery in. I tested it when I dropped it in, registered 12.57V. I cleared all the codes on the car, and took it for a drive. Fired right up, and I popped into the HVAC display (#20). I drove around for about 30 minutes, varying speed, etc. The whole time it registered between 11.3-11.7V. Seemed to go down a little bit the longer I drove. Pretty much held steady around 11.5-11.6V. Once I popped on the headlights it dropped down around 10.7V. When I turned them off it went back up to 11.5V.
Does this sound right? I still have the battery light lit on the speedo, but the bright yellow battery in the display is gone. Car drove great. I turned it off and started it again at the end of the drive and fired right up.
Is this sound correct, what should I do next for testing?
I really hate talking to myself...>
If it's not putting out into a good battery, it's NOT PUTTING OUT<ul><li><a href="https://forums.audiworld.com/tt/msgs/1730191.phtml">Hit the freakin link!</a></li></ul>
Would Autozone have a way to test specifically the output of the alternator?
It is either that or a relay, and I have no idea how to be testing for that, or where. I have a nice multimeter. I tested at the battery terminals while the car was running, and I was getting around 11.6-7.
