Problem with GIAC Chip?
Old Nov 14, 2004 | 09:25 AM
PaTTents's Avatar
New Member
Default Problem with GIAC Chip?
I have a GIAC Chip on my 2002 225 Coupe and many times at full throttle the rpms jump almost like a gear is slipping (the car revs but doesn't increase in speed). The dealer said that they could not find any problems with the gears and when I replace the chip with the stock chip the problem seems to disappear. Any thoughts?
Old Nov 14, 2004 | 09:27 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Clutch...>
The GIAC is providing enough of an increase in HP and torque to cause the clutch to slip...
There is nothing in the transmission that would cause this..
Old Nov 14, 2004 | 09:30 AM
PaTTents's Avatar
New Member
Default Re: Clutch...>
I had asked the dealer a few times to check the clutch and they said they couldn't find anything wrong with it, but they never took anything apart to look at it. Any idea on how much it is to replace the clutch?
Old Nov 14, 2004 | 09:33 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Lots...>>
Probably in excess of $1000.
If you drive a car normally a slipping clutch will not be evident. The much higher torque loads in upper gears that a chipped car develops
brings out the limitations. How many miles on the car? With a stock chip and relatively "normal" driving it could still last quite awhile..
Old Nov 14, 2004 | 09:36 AM
PaTTents's Avatar
New Member
About 55K.....
Hudson County 2.7T
Oct 11, 2006 06:25 PM
bleung
Aug 29, 2003 07:23 AM
EVIL-AUDI666
Jun 25, 2003 01:23 PM
cvtman
9
May 9, 2002 04:22 PM
RollerC
Feb 19, 2002 06:15 PM
