relationship between es bushings and vf engineering pendulum mount?
these are an either-or, right? that is, if i swap back in the stock rear engine mount, then i could then swap in the es bushings, correct? are there other bushings (e.g.,for the side engine mounts) that get replaced when switching over to the es ones?
thanks again
thanks again
don't know... HIJACK!!! Meem... I bought WHEELS! What spacers do I need again?
3mm front and 5mm rear for 19x8.5 ET30?
<img src="http://pictureposter.audiworld.com/58264/dscf0117.jpg">
<img src="http://pictureposter.audiworld.com/58264/dscf0116.jpg">
Not the greatest quality... and still cast... but I love 'em and with the Dolomite... I'm in love!
Pendulum mount bolts the tranny to the subframe >>>
and stabilizes the engine/tranny quite a bit compared to the rubber bushings in the stock mount.
Another option is to replace the rubber bushings in the stock pendulum with poly- ES, Turn2 ...
Engine mounts can be seen from the top (our motors are kinda suspended) and those you can replace the bushings on. Some good info with pics on the install process on the Turn2 site-
<a href="http://www.turn2usa.com">Turn2</a>
yes either/or, ES bushings replaces bushings in stock mount
VF mount is a complete unit that replaces the stock mount and bushings. VF makes side mounts for the engine also but that will make your ride even harsher. I think kodeTT has them.
absolutcq20v
9
03-06-2005 11:33 AM
Mike Desi
Audi Original "S" Cars
17
02-11-2005 12:46 PM
bsewall
12-19-2003 09:30 AM
Gunny to you maggot!
14
12-30-2002 12:06 PM
Taner Halicioglu
15
12-12-2001 10:14 AM
