Replacing OEM AC Compressor w/ GPD AC Compressor wiring question
The new GPD AC Compressor I bought has a square plug where as the OEM Compressor is a bit rounded at the edges. I've done some pretty extensive searching but I can't seem to find anything that identifies which wire has to be spliced with which and/ or if polarity makes a difference.
Does anyone know if I can just splice these up and hardwire the old plug onto the new any which way?
OEM Compressor has a Green and Yellow wire
New GPD Compressor has a black and black/ white wire
Thanks in a advance!
Black should be 12v+, black/white should be ground. I would check the source plug from the car to confirm polarity coming from the car and to make sure that is working. Also I would bench test the clutch to make sure the new compressor is solid before putting in the work to reassemble.
Here you go
also if you want to use a conversion harness they are out there too: https://a.co/d/iBZPP1H
Appreciate you!
hevnsnt
03-11-2022 10:03 AM
mz3bo
Q7 MK 1 Discussion
03-04-2020 04:00 AM
bnl107
10
11-08-2005 10:55 AM
