RH wheels + Pss9 coilovers...bad combo?
It appears that people with this setup and the 10" wheel (255/35/18 tire) have rubbing issues on the rear loacking rings? (perch)
If you have RH wheels and pss9's, please lemme know if you have this problem. THanks
no...the only rubbing issue might be if you lower to the max up front
you could possibly come into contact with the front spring perch..to overcome this I installed 8mm H+R spacers...up front only.
M,
M,
rocket s4
14
03-05-2004 04:42 PM
