Roadster: what's the least invasive way to route some wires to the trunk?
oh, and sills too, but the fronts and rear panels need to come off first.
<img src="http://woodyjdb.home.comcast.net/images/sillpanelremoval.jpg">
<img src="http://woodyjdb.home.comcast.net/images/sillpanelremoval2.jpg">
Thanks Jeff, that's what I was afraid of. Any suggestions...
I already tried removing the sub console and couldn't even get it to budge. I pulled the 4 torx screws in the sub compartment. I'm worried about breaking it if I pull it harder, any suggestions?
Mark
Mark
pull harder.
Get your finger in behind this edge of the opening, in front of the sub. Pull hard and sharp, *outwards*
<img src="http://ttbipes.home.comcast.net/jpgs/subgrille2.jpg">
see the vertical slot in the black metal right above the woof on the right side?
and then the ones on the top?
you are releasing metal clips in these slots, and they are in hard.
<img src="http://woodyjdb.home.comcast.net//images/newsub.jpg">
I went through the central tunnel...
Not that difficult to remove, since I already had the dash apart and the grab handles were removed. The most difficult part was removing the plastic piece just aft of the shifter.
<img src="http://images5.fotki.com/v89/photos/2/256520/1011580/DSC_1037-vi.jpg">
You have to remove the cupholder and a couple of screw underneath that panel, too.
<img src="http://images7.fotki.com/v126/photos/2/256520/1045703/Centerconsole-vi.jpg">
