SGI eyelids- now what?
AudiWorld Awesome User
- got a set
- fiberglass quality is much better now
- need to trim 'edges' for installation
Trying to remove the covers to allow insertion under the under-hood trim right above the headlight. Those 'pop-rivet' connectors: drive them down to remove the rivet and gain access? The Bentley CD-manual left out that detail, and I don't want to break one of the little blighters.
Push in the center abt 3/8"...
stick your hand under the cowl, if you push the center in too far, it will drop in your hand.
then you can release the main top or "button" easily
<img src="http://wildwingsacademy.home.comcast.net/images/plugs.jpg">
Push it in 3/8"? It doesn't go in...
I've had this same problem, and don't understand. I can't turn 'em, I can't pop 'em out, I can't push 'em in...
Could you give me an explanation for a dummy, because apparently that's what I am...
