Silly Strut bearing question
I'm replacing the bearings and bushings soon... I have looked at two write ups (marTT and schwing)...
In marTT's he uses a hazet tool and or a spark plug socket with a wrench on it...In steve's, he uses air tools...
If using an impact gun, is there no need for the hazet or spark plug socket?
here's my experience >>
if you are not reusing the struts you are removing - take it off with an air gun (but don't put anything back on with one) if you are keeping the struts and just doing bearings and bushings... use this >>
<img src="http://www.metalnerd.com/images/products/cat05/mn2122.jpg">
it allows you to put a 3/8" drive ratchet through it to hold the inner strut nut steady as you take the outer securing nut off.
use this to put them back on as well.<ul><li><a href="http://www.metalnerd.com/cat05.htm">http://www.metalnerd.com/cat05.htm</a</li></ul>
2PUTT
02-07-2007 02:56 AM
Europa
10-05-2006 10:05 AM
Žob
01-19-2004 03:03 PM
skiddmark
07-01-2002 04:40 AM
