so my mechanic received my blueflame exhaust today and i have a problem>>
#51
thanks a ton for the prompt response! i'm sitting in my car with my mac>>
with the car on the ramps even as we speak..i'm not going to give up...everything is intact now, so i can drive it...now tell me where i can get the nut breaker or WD type penetrant-NAPA auto parts? advanced auto? Thanks once again!!
#52
Any auto store...>>>
PB Blaster is really good stuff. Shoot the rubber donuts to and they'll slide off easier. YOu can also unbolt the mounts and deal with the donuts when everything is off the car. There are (2) 13mm bolts on each side. You'll need an extension to get to them but you may find this easier than wrassling with the donuts.
BTW, I use this tool for removing and installing the rubbers. Available at Sears:
<img src="http://images111.fotki.com/v729/photos/7/7305/305103/DSCF0055-vi.jpg">
#53
so steve, can i use this PB blaster to loosen the center clamp bolts as well?>>
loosening the center clamp bolts is my main concern now, because everyone including you started there...is there a possibility that even after using a liquid penetrant, the bolts do not rotate? i asked my local napa guy, he said i'd have to spray the penetrant and let it work on it overnight!
#55
thanks and sorry for making you repeat ...i went to ace hardware, enquired for>>
PB blaster, they didn't have that in stock, gave me a WD-40. let's see if that can loosen the bolts.....thanks again to both you and horch it!!
OndrejAudiA420
11-22-2008 09:51 AM
kday
Audi Original "S" Cars
11
09-14-2006 08:53 PM
