Spacer installation..
Are spacers hard to install? I was thinking about some for both front and rear. Just thought I'd get some input on which spacers are good and for the right amount of money and how easy/hard the install is. Also, if I install spacers and springs would I also need a kmac kit? TIA!
-Krit
-Krit
Re: Spacer installation..
Spacers are really easy to install. Remove tire and bolt on spacer and and then bolt rim back on.But get H&R Spacers.. Contact this guy Billito13@aol.com, he has a shop in Miami and he has really good prices on all Audi/VW stuff, especially H&R stuff. I'm thinking of getting a body kit from him
Only some of the spacers bolt onto the hub; others slide on over the hub and are sandwiched between the wheel and the hub. You will have to calculate the length of the longer bolts you will need, depending on the wheels you have (and their stock bolts). Add this to the cost of the spacers when you're figuring...
Fig
Fig
lx4life
03-22-2018 05:35 PM
Spacers ? Is it better to get the bolt on kind or the one that just slips in between the rim and the
maaliish
05-04-2005 09:03 PM
TTapsale
06-01-2004 08:33 AM
