still disappointed in my shift feel-- thoughts? >>
Took the TT to Induktion today-- got stainless brake lines installed, did a brake flush with motul fluid and had the milltek installed.
Also, had them do a gearbox flush with motul synthetic and adjustment to the shift linkage at the short shifter. As you may recall, I have an HPA short shift kit, which I have set at 35% reduction (there are two settings).
Unfortunately, neither change helped my shifting feel. It is slightly less difficult to shift; however, I'm beginning to worry that it's just a factor of shifting via cable and short shifters.
again, the feeling is this: each shift feels like it has too parts: half the throw, then a pause, then the rest of the throw. It's the feeling of something being shoved through a rubber grommet or something.
I'm getting to the point where it's seriously annoying me that I can't fix it. Going back to a full throw is not an option.
Junior Member
I have the same feel with my Forge SS, would this help us ..
I though it was my transmission going, that is what i feel too: half the throw, then a pause, then the rest of the throw, kind of like it gets stuck.
http://www.ttstuff.com/performance_shift.php
B&M Short Shift Kit
B&M Short Shift Kit
For Audi TT 00-04 quattro - 45146 - New Version
Complete kit with full directions. Reduces shifter throw by approximately 30%. New kit now accepts the stock shift ****!
B&M **** is no longer included. Engineered for precision shifts.
$219.99
B&M Short Shift Kit
B&M Short Shift Kit
$219.99
Junior Member
i thought you said your problem comes from the SS....
your descriptions souds exactly like my problem.
I have mine set to the max.. 40% F-B and max side to side ?%
most have some type of alignment tool or adjustment>>>
the Dieselgeek solution was "off" for me until i made some minor adjustments...Cannot speak for Forge or HPA, but i would doubt either would want you to be unhappy...
Call their support lines for help, you may find an answer there...
If you insist on a big reduction.....>
I'm not sure you can get around it. The VW/Audi Cable set-up seems far less precise and controlled than some other brands. That and the actual transmission shifting characteristics result in a less than satisfactory shift feel. The old 20% Diesel Geek original felt absolutely great and shifted like butter on my car. But 20% was not "Racy" enough for many. Nothing I've ever tried felt better on the TT. Some, like the B&M, are absolutely miserable. Before you blame it on Cable shifters in general, I had a 50% reduction unit in my Boxster and it was every bit as precise as the solid rod shifter on my Vette..Honda in general also does a good job with their Cable shifter feel..
Start with an imperfect situation, then accentuate it with a Big reduction % and you get what you got...:-(
