Stud Conversion
Old Feb 16, 2005 | 12:53 PM
TonyStarkz's Avatar
Default Stud Conversion
How do you bolt in the studs? I mean there is no beveled surface for any tool to grip on without messing up the threads. Any insight?
Old Feb 16, 2005 | 12:55 PM
TTagz's Avatar
Senior Member
Default I'm not sure what you are talking about, but...
to screw in a stud you just double nut it.
Old Feb 16, 2005 | 01:06 PM
mcgilla's Avatar
Stud Conversion: Wheels?...I did convert my hubs to studs
Old Feb 16, 2005 | 01:37 PM
MaxHedrm's Avatar
Man...I need to get my mind out of the gutter.
Old Feb 16, 2005 | 02:04 PM
JustJeff's Avatar
Some will have a hex-head insert in the end of the stud.
Old Feb 16, 2005 | 04:26 PM
TonyStarkz's Avatar
Yes I was referring to wheel studs....thanks Jeff.
Old Feb 16, 2005 | 07:18 PM
Russ Scott's Avatar
Default Here's one >>
<center><img src="http://pictureposter.audiworld.com/34314/stud.jpg"></center><p>Like you said, Jeff: A hex is machined into the stud's end. Using a wrench like that pictured, it screws right in, without need for double nutting. Also note: the un-threaded portion of the stud is a "stop". This prevents penetrating too far into the hub.
Old Feb 17, 2005 | 04:44 AM
TonyStarkz's Avatar
And these are safe to use w/ spacers, correct?
 Michael S. Palmer
Old Feb 17, 2005 | 07:16 AM
Russ Scott's Avatar
Default Absolutely....
<center><img src="http://pictureposter.audiworld.com/34314/stud.1.jpg"></center><p>
They come in "lengths", so getting the length right is important! To short: you'll have inadequate "stud to nut" thread contact. In most cases "overlength" is used with open ended lugs. In my case I wanted to use Porsche aluminum lugs (Porsche uses these on all their street cars, even turbos. Real race cars get steel). Being closed ended, I couldn't use overlength because the nut bottomed on the stud, before it contacted the wheel! Vendors include H&amp;R (a disaster, their 40mm stud is actually 50mm, hence the bottoming incident) 2Bennett and Upgrade Motors in SoCal (pictured). The TT uses 14 x 1.50, diameter and pitch.<ul><li><a href="http://www.upgrademotoring.com/wheels/whl_acc.htm">Upgrade Motors</a></li></ul>
Old Feb 17, 2005 | 08:06 AM
TonyStarkz's Avatar
Thanks!
