Successful thermostat replacement today (whew!) >>
Thanks to RafaTT for the great write up (see URL below). Yes I was one who had the Wahler thermostat as part of the ECS kit and the car showed it was running hot. I did this mod in conjuction with the EvoShield phenolic intake spacer mod (not good so far, I think a vacuum leak needs to be tracked down) but the thermostat is in! Of course I have not run the car much to tell you if it's still running hot or not. (I'll post on that later.) Not really easy, the bottom 10mm is a real bear to get out and get back in. Just takes patience and sometimes another pair of hands (thanks Mike!).
<img src="http://images10.fotki.com/v196/photos/4/41970/2378449/thermostat002-vi.jpg">
<img src="http://images10.fotki.com/v197/photos/4/41970/2378449/gasket027-vi.jpg">
<img src="http://images9.fotki.com/v171/photos/4/41970/2378449/gasket025-vi.jpg">
<img src="http://images9.fotki.com/v198/photos/4/41970/2378449/gasket029-vi.jpg"><ul><li><a href="https://forums.audiworld.com/tt/msgs/1304805.phtml">RafaTT thermostat replacement</a></li></ul>
Thanks, I wonder if one I got with my ECS' timing belt kit is same as yours
Why would the one they provide have a different temperature spec? did you find out from them to send you another one in case it was defective?
This has been discussed at great length recently . . .
Yes, ECS uses the Wahler thermostat.
Check this link for more:<ul><li><a href="https://forums.audiworld.com/tt/msgs/1303829.phtml">Thermostat Chat</a></li></ul>
You almost certainly have the "hot" one as well. See Rafatt's excellent
description of the issue at the link below.<ul><li><a href="https://forums.audiworld.com/tt/msgs/1303829.phtml">Rafatt's Thermostat Sleuthing</a></li></ul>
03AR2rescu
Audi allroad
01-03-2009 10:27 PM
2PUTT
NY / NJ / CT Discussion
09-18-2008 06:30 PM
beltway
07-10-2008 01:45 PM
~DonQPremiumTequila~
33
05-01-2007 02:42 PM
CusTTom "Quag" WesTT
07-27-2004 06:25 PM
