SURVEY TIME!
Old 10-26-2001, 01:27 PM
  #11
HACK THS's Avatar
'00 180 TTC, 3/00 build, 30,000 mi, Xenon problem, DV problem
Old 10-26-2001, 01:28 PM
  #12
Elder Member
tsltm's Avatar
2000, built 1/99, 36248, too many too list (obviously the pros outweigh cons on this car)
  #13
Levent's Avatar
It's Brilliant Black ;-)
Old 10-26-2001, 01:35 PM
  #14
Elder Member
Larrytt's Avatar
Default 2000 180TTQ, built Aug '99, 39,600 miles . . . rest is inside . . .
Everything has been repaired except where noted.
1. 7 fuel sending units
2. 1 instrument cluster
3. Light/lock "bug"
4. Horrible AM reception, hopefully fixing tomorrow.
5. Defective DV Design . . . installed Forge, changing to Turbosmart shortly.
6. AoA Customer Support, leaves LOTS to be desired!
  #15
New Member
BrenTT's Avatar
2000 TTC FWD, Built 5/99, No Major Problems or Concerns.
Old 10-26-2001, 01:44 PM
  #16
Member
Colonel Bogey's Avatar
Default 2001 225R, 11/00,18K, seat wear (grn), door jam squeaks - both corrected.
Used 1 quart oil over 1st 10K miles and zero over subsequent 8K.
Old 10-26-2001, 01:47 PM
  #17
New Member
Blue Nose's Avatar
2001 TTR, built 01/01, 6K miles, DV and fuel and temp guage sticking
  #18
Junior Member
RogerL's Avatar
Default 2000 180TTQ built 10/99 39,300. No problems last 10k, but..
A few glitches early on:
seat heater switch
tire bulge
DV
ESP sensor replaced (ESP done under vol. recall)
LF wheel bearing replaced
Temp sensor replaced
DV
sway bar bushings replaced.
More than happy with it. Dealer seems better than most. No glitches lately.
Old 10-26-2001, 01:48 PM
  #19
Tron (///M)'s Avatar
Default 2001 180 QC. 7500 Miles. Windshield, door & window squeaks, head rest squeak. and bad flywheel.
I am still trying to convince the dealer about the flywheel. Funny I brought the car in and brought the Service bulletin which explained the symptoms I was having. After dropping the car in the morning I get a call at work saying: "Oohh your tires needed balancing that's why the car has a vibration". Go figure. I still love my car though.
  #20
New Member
scoTTwouw's Avatar
Default 2001 180FWD 4k miles
Creaking suspension - fixed.
Rattling glovebox - waiting until 5k service
Privacy self not staying on - fixed.
Quick Reply: SURVEY TIME!
