Thumping and shuttering feeling while wheel is turned >>
I only feel it at slow speeds after turning the wheel all-the-way before and after pulling in or out of a parking spot. I've seen different reasons in searching, but nothing specific.
Thanks.
Thanks.
Only at slow speeds I feel it...
on sharp turns in the parking lot. The thumps get faster if I move faster... only noticed it after turning very sharp right, then backing up. Not a loud noise... maybe "thumping on the tire" kind of noise, but sounds like it's maybe coming from the suspension. Feels like rolling over something. The post below sound like the same problem.<ul><li><a href="https://forums.audiworld.com/s4b6/msgs/375375.phtml">https://forums.audiworld.com/s4b6/msgs/375375.phtml</a</li></ul>
my TT has always made a rather loud ratcheting noise when turning
very sharp at low speeds. Dealer kept the car, replaced several items, including bars, and it still does it. Says they can't track it down.
It doesn't seem to be hurting anything...
Good luck my white brother!
Mild vibration at near to full lock could be power steering fluid (it was for me) >
I'd check that first but your case sounds a little more serious than "mild vibration." Good luck.
I have this problem now working on resolving it...
I was told to check the power steering fluid top it off if its low. Also as belts get older it could be the serpentine belt on the power steering pump this is usually changed out when you do the timing belt though. Ive also been told that there is a fluid at pepboys that supposedly stops the knocking not confirmed thought.
S4iowa
08-07-2007 05:36 PM
Need Help wat does it mean wen my car is making a squeaking noise, like a rusty wagon wheel noise...
amercour
13
02-20-2006 07:28 PM
SFV A4
01-28-2006 01:48 PM
juttin
01-03-2004 12:10 PM
kritzer007
09-07-2003 08:13 AM
