tire issue...
tire issue...
i had my alignment checked and everything was in spec. the tire has substantial wear on the inner side and has some pretty severe feathering. i did go 12,000 with out rotation (i know, dumb. had a broken arm) is this wear solely from the lac of rotation or should i be looking for something else? i assume my next place to look would be for a bad shock. any pointers would be appreciated.
TIA
TIA
Your out of alignment.
Probably has toe issues. I had and still have that problem, had to installa a full KMAC to get the problem to go away with the correct alignment adjustments
If you are lowered, the Audi spec is useless, and you should be out of it, with a camber
correction system (KMAC or adjustable tie bars) on the rear suspension. If you didn't tell them what to shoot for, they likely use the Audi numbers, which change with ride height, as the OEM suspension is not adjustable. This would result in a higher degree of wear, on the inside edge of the rear tires (as would bad toe).
iNfiNkC
29
05-31-2008 07:56 AM
mxp
03-21-2008 06:03 PM
RageRacer
09-11-2005 08:56 PM
