Trans problem
Old Jan 17, 2007 | 02:07 PM
TCU_TT's Avatar
Default Trans problem
I have been having problems with shifting lately. I have had to put a lot of pressure to get my car to go into gear. Plus when going out of reverse it stays in reverse. I set there and move the shifter around and it finally comes back up to go into first. It seems like after it warms up for a bit shifting gets a little better. Also if I set there while warming and leave the clutch in and shift through all gears a few time it gets better. The weather has been really cold here in Fort Worth. Could that have a hand in this. This is the first time my car has done this and I driven in cold weather before. Any ideas? TIA
Old Jan 17, 2007 | 03:05 PM
PracTTical's Avatar
Default colder weather makes for crappy shifting.. >>
i have redline MTL in there and have to double clutch my way to work... try checking shift linkage and then replacing your MTL.. i recommend 2 qts redline MT-90 and 1 quart MTF (for the cold days)
Old Jan 17, 2007 | 03:47 PM
DasTT's Avatar
Default How cold? -->
My car sits outside at 15 degrees and shifts just fine. I've got MT-90 in mine and with the DG short shifter. No issues at all.
You could have low fluid from a leak or binding on the synchros or they are simply worn out. How many miles?
Old Jan 17, 2007 | 03:56 PM
TCU_TT's Avatar
Default Its in the lower 30's here.
I have 65,000 miles on it. I also have the stock fluid in it.
Old Jan 17, 2007 | 04:16 PM
MiliTTary's Avatar
I have the same problem at Fort Lee, its just the cold.
Old Jan 17, 2007 | 04:18 PM
TCU_TT's Avatar
Default Yea thats what i'm thinking...
I just wanted to see what other people though before I tore something up.
Old Jan 17, 2007 | 06:31 PM
MCPaudiTT - DEFCON 1's Avatar
Tech Guru
Try aligning your shift linkage. Great instructions on Diesel Geeks site.
ChronoGN
Dec 2, 2008 09:41 AM
loder
RS4 (B7 Platform) Discussion
Aug 30, 2008 06:48 PM
keman
Dec 9, 2005 11:17 AM
EGainer
Jun 2, 2004 12:11 PM
GeTTin
9
Jan 13, 2001 12:51 PM
