trouble changing brake pads.
So today I tried to help my friend change his rear brake pads on his TT (180 non q). I followed some instructions that I found from doing a search. I got everything off okay but couldn't get the piston to compress. I used a pair of pointed vise grips and turned the piston 360 degrees but it still didn't compress. Am I doing something wrong?
Any other links out there with instructions?
you need to turn and compress the piston at the same time.
The red clamp is an edging clamp, about $3.00 at just about any good hardware store.
Blue is a large 'water pump' pliers
Don't pinch the vinyl boot.
<img src="http://home.attbi.com/~jbipes/jpgs/rearbrakes10.jpg"><ul><li><a href="http://home.attbi.com/~jbipes/ttr/frntrotors.html">Rear Brake Install</a></li></ul>
mattc12
06-12-2017 03:46 AM
OneGuyInCA
12-04-2007 09:01 AM
Seanism (clone510)
05-12-2005 06:14 AM
PhilMason
15
10-17-2001 05:41 PM
