TT overheating
Old Apr 15, 2006 | 05:29 PM
DorianL's Avatar
New Member
Default TT overheating
My 2002 Audi TT Quattro started overheating couple days ago. Also A/C won't work. No cooling. A/C compressor is charged, there's freon. Coolant is also normal level. What happened? Anyone? Is it an electronic problem?
Thanks for the replies.
Old Apr 15, 2006 | 05:36 PM
jackTTar's Avatar
Member
Default hmm... could be coolant temp sensor and/or the water pump impeller...
have gone bad.
Have either the coolant temp sensor or water pump been replaced already?
Old Apr 15, 2006 | 05:38 PM
DorianL's Avatar
New Member
Default Re: hmm... could be coolant temp sensor and/or the water pump impeller...
Not that I know of. I'm the second owner.
Old Apr 15, 2006 | 10:14 PM
eqsTT's Avatar
Default not likely to be your problem but.....
I had a weird case were the box ontop of the battery that holds some fuses actually melted (caused problems with my AC)
and I had the Fan stop before which caused some overheating (do you hear your fan kick on?)
Old Apr 16, 2006 | 07:53 AM
DorianL's Avatar
New Member
thanks for the tip
Old Apr 17, 2006 | 04:37 PM
DorianL's Avatar
New Member
Default It WAS my problem!
I jiggled with those fuses on top of the battery and the fan and the a/c came on! Great help. Hope this info helps somebody else.
Sindija Lauma
Jan 9, 2017 11:29 PM
AudiAMM
Apr 26, 2016 08:13 AM
federal
Apr 30, 2014 04:28 AM
federal
Dec 1, 2007 11:32 AM
green a4 sIII
May 8, 2004 11:34 PM
