VAGCOM question????
No....>
Those are long term adaptation values built up over time. They will show no instantaneous change. YOu can measure those stored values with the car not running (ignition on). If you pull the battery cable those values will revert to "0" and then be revuilt over the next 20-30 miles as all the systems adapt again..
If they're showing "0"....>>
You're not getting a reading. Using a shareware Vag program? They don't allow access to all blocks..The chances of both values being "0" is slim to none..
You want to be a little on the rich side (-1.5 or so) on part throttle...>>
and a little lean on idle. With the 3bar FPR you are too lean on the part throttle and with the **** and 4Bar, too rich on part throttle. Mine was around -3.4 which is fine for most.
I adjusted my adj. FPR and made several WOT runs in 3rd gear on the highway and adjusted until I got the results above.
Once you get the FPR dialed, you will notice a more smooth ride all the way up the rev.
Hope this helps.
Hope this helps.
would there be a reason why its not reading it right?>>>
Does APR get rid of some of those thing when they chip your ECU? I thought I heard an APR guy say they deactivate some things.
