Warning Lights...
But the thing is... these warnings only come on when I push the button. Does this mean that I need to check the oil pressure and coolant? Why does it only flash when I push the button?
Thx for the help!
When you start the ignition you should see the "OK". IF there is a malfunction THEN one of the symbols you mentioned will flash instead of an "OK" along with a warning tone indicating what the problem is.
It's all in the manual.
