Help on the indicator lights
Old Mar 7, 2006 | 11:50 AM
707782's Avatar
New Member
Default Help on the indicator lights
I have a 02 Audi, A4, Quarttro 3.0, V6, 98K miles
When I pressed the check button, couple indicator symbol comes up, they're the following:
Coolant temperature and level---the symbol is moving, what does this indicate, I just check the coolant, and it has enough, but I don't know why the indicator light is on.
Oil pressure----What does this indicate? Does it mean that I have low oil, or I just have to changed the engine oil?
Brake pads worn light--this light is not red, I don't know if they suggest me to change it, or there's something wrong with it.
Old Mar 7, 2006 | 12:39 PM
707782's Avatar
New Member
Default Re: Help on the indicator lights
Anybody able to give suggestion? Is it just running through the normal check points or is it the indication of problems? It does not come on by itself, I have to press the check button, and in the end, it did say "OK"
Old Mar 7, 2006 | 01:52 PM
swizzchard's Avatar
it says 'ok' so you're ok
Old Mar 7, 2006 | 04:06 PM
Avantadrive_Original's Avatar
dude, read the manual, seriously
Old Mar 19, 2006 | 08:32 AM
cknyc's Avatar
New Member
Did you get any answers to your problems? I just started getting the same coolant indicator light on even though the coolant temperature and level is okay. Thanks
hellonwheels33
32
Apr 16, 2023 07:32 AM
davidbod
Q7 MK 1 Discussion
36
Jul 25, 2022 07:57 PM
eggsngrits
Dec 8, 2021 06:58 PM
scottnybottny
Sep 23, 2017 06:28 AM
jforman
A6 (C7 Platform) Discussion
10
Sep 8, 2015 10:03 AM
