Weird Thud
#11
Do you have the part numbers of what was replaced? There is only one transmission mount
one motor mount, and the dogbone. I am curious if they replaced one side when both were needed? They should have also used new bolts to install the mounts (check the parts list).
You can see what's involved in replacing all three mounts here at the link...<ul><li><a href="http://public.fotki.com/mcphill/audi_stuff/engine_and_drivetrain/vf-engineering-engi/">The link...</a></li></ul>
#13
Re: Do you have the part numbers of what was replaced? There is only one transmission mount
The exact issue was addressed as follows on the receipt:
"Concern: Customer added there is a cracking noise in the front end while taking off and when switching from drive to reverse.
Cause: Trans mount has failed
Correction: Replaced trans mount
Pars: PartNumber
VWN 8N019955E
Description Gear Mount
SPO 8N019955E
VWN N 10209605
Description Bolt
VWN N 90596902 Bolt
Description Bolt
VWN N 10155906 Bolt
Description Bolt
This is all the information listed on the receipt. This work was performed on 06/16/08.
Pars: PartNumber
VWN 8N019955E
SPO 8N019955E
VWN N 10209605
Description Bolt
VWN N 90596902 Bolt
Description Bolt
VWN N 10155906 Bolt
Description Bolt
#14
Re: Let us know how it goes.....
Pars: PartNumber
VWN 8N019955E
SPO 8N019955E
VWN N 10209605
Description Bolt
VWN N 90596902 Bolt
Description Bolt
VWN N 10155906 Bolt
Description Bolt
This is all the information listed on the receipt. This work was performed on 06/16/08. Did they replace the right part?
Pars: PartNumber
VWN 8N019955E
SPO 8N019955E
VWN N 10209605
Description Bolt
VWN N 90596902 Bolt
Description Bolt
VWN N 10155906 Bolt
Description Bolt
#15
Re: as you have not put a lot of mileage on the car.....i would not wait>>
I scheduled an appointment for tomorrow morning. Is there anything else in particular I should have them take a look at? Can you explain to me what the rear engine mount is. I thought there was only one engine mount in the front.
#16
Re: Exact bolts used
Here are the bolts that were used:
VWN N 10209605
Description Bolt
VWN N 90596902 Bolt
Description Bolt
VWN N 10155906 Bolt
Description Bolt
Are these the right bolts?
VWN N 10209605
Description Bolt
VWN N 90596902 Bolt
Description Bolt
VWN N 10155906 Bolt
Description Bolt
#17
8N019955E is the transmission mount. The engine mount is 1J0199262. It does look like they
used new bolts for the mount, so hopefully the torqued them correctly. Maybe your engine mount needs replacing as well, or maybe the bolts for the tranny need to be re-torqued (if done incorrectly or if they somehow loosened).
Parts listed at the link:<ul><li><a href="http://public.fotki.com/mcphill/audi_stuff/engine_and_drivetrain/vf-engineering-engi/vfetka2.html">Link</a></li></ul>
#19
Re: 8N019955E is the transmission mount. The engine mount is 1J0199262. It does look like they
I am a little bit confused. When you or others refer to the dogbone mount are y'all refering to the engine mount or something else. How many mounts are there?
#20
Re: second that....or if the bolts were stripped and overtorque could cause this too..
If the engine mount is bad or the tranny mount bolts are over torqued or stripped could this cause poor acceleration or not smooth shifting between gears? Just wondering.
