What is the length of an OEM wheel bolt? Went to discount tire to pick...>>>
up some wheel bolts for SSR competitions and they gave me wheel bolts that measured 20mm from 1st thread to end of bolt. Is this the correct length? Seems like I can go a little longer. The tech said that I don't want it too long or else it will hit the rotors.
measuring that way you might be ok; usually you measure from the seat of the bolt >
<center><img src="http://pictureposter.audiworld.com/53277/dscn0506.jpg"></center><p>and that's about 28mm on the OEM's.
Well, measuring from the seat of the bolt only gives me another 2mm...>>>
so about 22mm total. Do you think this is still safe and ok to use or should I go back and return for longer bolts?
It also depends on the thickness of the wheel. SSR could probably tell you.
I also think I remember something about the number of threads required to provide the proper friction & clamping force. I want to say 7. & looking @ GorTT's pic, that looks about right.
needforsleep
Wheels & Tires Discussion
13
11-18-2003 11:06 AM
SteveTT
01-28-2002 11:39 AM
