Where can I get a somewhat affordable set of replacement headlights
If you can take your old ones apart, you can troll ebay and find some
with broken tabs for pretty cheap. Several people here have done so. I picked up a set of 2005 S lines for $170 shipped. The outer housings are toast, but with all the internals and the lenses, it was a great find.
Good Luck!
Good Luck!
A whole used headlight is the way to go for the money... (edit)
But you should do what you want. If you want brand new lenses, then you probably won't be satisfied with used lenses just because you got a great deal on all the internals...
meem bought new Halogen headlights, and pulled them apart and put the new lenses on
the old xenons. a less expensive alternative, especially if its just the outer lens that you want to replace. also, you will have to pull them apart if you want to do the clear corners.
Betty Humpter
Audi 100 / A6 (C4 Platform)
05-20-2009 08:59 PM
tganci
06-27-2006 07:59 AM
Foursquares
02-15-2005 05:45 PM
A4orce CJ
03-30-2003 11:37 AM
