where can i learn to read the requested vs actual boost.
Those logs you sent me have most of it but...>
Actual boost at the Manifold on the VAG is a calculated number (not real) based on MAF flow. The command is requested boost, the IC is actual boost measured downstream at the MAP sensor in front of the battery.
True manifold levels can only be measured with a gauge as there are certain things happening within the manifold via valve timing, reversion etc. that result in higher numbers than the IC levels would indicate.
nt2old4ns4
11-20-2006 12:08 PM
S4Poor@Curbside
02-02-2006 06:17 AM
ArandA4
VAG-COM Discussion
07-20-2004 02:02 PM
zszabo
02-14-2004 09:15 PM
