whom here did a DD downpipe while they upgraded the clutch
Old Jul 24, 2008 | 10:02 PM
Horch it's Avatar
Default whom here did a DD downpipe while they upgraded the clutch
the OFE South Bend clutch should be here nexd Tuesday and I am contemplating doing the downpipe while I got the tranny out, and, and, while I'm in there, might as well do the induction samco hose....thoughts and or warnings, tips, etcetera, etcetera, etcetera...
<img src="http://i6.photobucket.com/albums/y205/GLDE8R/brembo1.jpg">
<img src="http://i6.photobucket.com/albums/y205/GLDE8R/TT_Brembo.jpg">
Old Jul 24, 2008 | 10:20 PM
DynomiteTT's Avatar
do it.... i did the front sway and DP at the same time since i had the subframe dropped.
Old Jul 24, 2008 | 10:34 PM
Russ Scott's Avatar
Default raises hand :)
most found it necessary to put a poly dogbone bushing in place to prevent the larger diameter DP from hitting the undercarriage. But mine didn't... I ran stock motor mounts for quite awhile.. ymmv
I think it's a good idea to put in a new slave cylinder/throwout bearing assembly with a new clutch. An "ounce of prevention" etc. If the old one's left in place, and decides to leak, it'll hose down your new clutch with brake fluid. Spend $80-ish on the slave up front and improve the odds. Skimp on the $80: risk buying <i>another</i> new clutch and a "re-do" of all the associated labor
Old Jul 25, 2008 | 05:02 AM
kappa-q's Avatar
Default Re: whom here did a DD downpipe while they upgraded the clutch
Do it, but keep in mind you may encounter a 2+ week wait while 42DD makes a kit up, unless you find a reseller who keeps one in stock.
Old Jul 25, 2008 | 06:12 AM
Horch it's Avatar
Default the best price I've seen is from TTstuff
thanks for the schedule heads up!
Old Jul 25, 2008 | 06:15 AM
Horch it's Avatar
Default Yes, indeed, I got the complete kit
with T.O. bearing and the slave....I wouldn't be surprised if the slave is leaking a bit already. I am starting to get shudder and slippage uphill especially long drive ways with high grades...and then the smell of clutch...and I don't feel the clutch holding my torque like it use to....
Old Jul 25, 2008 | 06:16 AM
Horch it's Avatar
Default did you ever get any cel
with the DD dp? O2 sensor issues?
Old Jul 25, 2008 | 07:33 AM
carsluTT's Avatar
sounds like the best time to do the install on fhe DP to me
Old Jul 25, 2008 | 10:46 AM
DynomiteTT's Avatar
nope not with the O2 angle block. and i run the test pipe.
Old Jul 25, 2008 | 11:05 AM
Horch it's Avatar
Default ah, the angle block....
and did you have the poly dogbone bushing installed as well, ala Russ Scott? to prevent the larger diameter DP from hitting the undercarriage?
