Wierd Temperature problem continues - technical opinions requested
Dreaded Glitch..
And is anyone tells me to put my window down or use "econo" and just pull in outside air I will smack them silly AND YES it's going to the dealer on WEDs.
1. Origainally the a/c system Spitting out HIGH HIGH HEAT! ambiemt temp 69, "calling" for 68 degrees
2.THEN eventually the outside temp indicator in the middle of the dash was either GONE (blank) and when it reappeared it reported 12 degrees lower difference. It is GONE today.
3. A couple times a Loud clicking sound came from under the hood, then interior fan was going BONKERS IN SYNCH WITH THE CLICKING blowing fast - slow and to make it wierder alternating the vents too!!
4.Investigation showed that the Clicking noise from under the hood was the radiator fan being turned on for ONLY a second, then before it even got up to speed another loud click & then fan was turned off. This was repeated 10- 20 times over a minute. And as I said the interior fans seemed to react to this turning on & off of the Radiator fan
Well any ideas?
Rik
Well any ideas?
Rik
allroadCole
05-12-2008 07:45 AM
MikeNSX
Audi 100 / A6 (C4 Platform)
11-14-2004 08:12 PM
Driver8
07-15-2002 08:24 AM
Paul3.2A4avant
Audi allroad
05-30-2002 10:29 AM
