will a front sway bar help the "sliding out" of the front wheels durring a quick start into a bend?
not always though
"Stiffer front sway bars will, in many cases, decrease understeer because of reduced body roll and better camber control."<ul><li><a href="http://www.rogerkrausracing.com/overundr.html">http://www.rogerkrausracing.com/overundr.html</a</li></ul>
Alright then this is where I'm at now...tire pressures right?
I have the alignment set to full modshack alignment spec.
The HPA's are set half an inch higher in the back than the front.
I havent checked tire pressures yet (recently just put on). but is anyone running a dry only tire like Falken Azenies and what pressures should I use, I've been reading 3 more psi in the front than rear apparently?
The rear H&R bar is set to the stiffer setting.
with this info tire pressure is the next thing i should be looking at?
Equalize your pressures....>
That big rear bar is tending you toward oversteer. Reducing front pressures will result in a better and safer balance...
Drive it and see...Adjust as necessary..
I run 36/36 and it's perfect for my set-up...YMMV
